πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.8 LED Matrix Module
Overview
In this lesson, you will learn about LED Matrix Module. LED Matrix Module uses the MAX7219 driver to drive the 8 x 8 LED Matrix.
Components Required
../_images/list_2.8.png
Fritzing Circuit
In this example, we get the VCC pin of MAX7219 connected to 5V, GND to ground, DIN to digital pin 12, CS to digital pin 10, CLK to digital pin11.
../_images/image443.png
Schematic Diagram
../_images/image444.png
Code
  • You can open the file 2.8_ledMatrix.ino under the path of sunfounder_vincent_kit_for_arduino\code\2.8_ledMatrix directly.
  • The LedControl library is used here, you can install it from the Library Manager.
    ../_images/lib_ledcontrol.png
After the codes are uploaded, you can see that the LEDs turn on in the sequence of a column, a row or a dot or there is a picture appearing on the LED matrix.
Code Analysis
By calling the library LedControl.h, you can easily use the LED matrix.
#include "LedControl.h"
Library Functions:
LedControl(int dataPin,int clockPin,int csPin,int numDevices)
Create an instance of type LedControl through which we talk to the MAX7219 devices. The initialization of an LedControl takes 4 arguments.
  • dataPin,clockPin,csPin: The first 3 arguments are the pin-numbers on the Arduino that are connected to the MAX7219. You are free to choose any of the digital IO-pins on the arduino, but since some of the pins are also used for serial communication or have a led attached to them its best to avoid pin 0,1 and 13.
  • numDevices: The fourth argument is the number of cascaded MAX7219 devices you’re using with this LedControl. The library can address up to 8 devices from a single LedControl-variable.
void shutdown(int addr, bool b)
  • addr: The address of the display to control.
  • b: If true the device goes into power-down mode. If false device goes into normal operation.
void setIntensity(int addr, int intensity)
Themethod lets you control brightness in 16 discrete steps. Larger values make the display brighter up to the maximum of 15.
  • intensity: the brightness of the display. Only values between 0(darkest) and 15(brightest) are valid.
void clearDisplay(int addr)
All LEDs off after this one.
void setLed(int addr, int row, int col, boolean state)
Set the status of a single Led.
  • row: The row of the Led (0..7).
  • col: The column of the Led (0..7).
  • state: If true the led is switched on, if false it is switched off.
void setRow(int addr, int row, byte value)
Set all 8 LEDs in a row to a new state.
  • row: Row which is to be set (0..7).
  • value: Each bit set to 1 will light up the corresponding Led.(e.g. B01000000 will light up the 2nd).
void setColumn(int addr, int col, byte value)
  • col: Column which is to be set (0..7).
Phenomenon Picture
../_images/image109.jpeg
