2.26 Photoresistorï
Overviewï
In this lesson, you will learn about Photoresistor. Photoresistor is applied in many electronic goods, such as the camera meter, clock radio, alarm device (as beam detector), small night lights, outdoor clock, solar street lamps and etc. Photoresistor is placed in a street lamp to control when the light is turned on. Ambient light falling on the photoresistor causes street lamps to turn on or off.
Components Requiredï
Fritzing Circuitï
In this example, we use analog pin ( A0 ) to read the value of photoresistor. One pin of photoresistor is connected to 5V, the other is wired up to A0. Besides, a 10kΩ resistor is needed before the other pin is connected to GND.
Schematic Diagramï
Codeï
You can open the file
2.26_photoresistor.inounder the path ofsunfounder_vincent_kit_for_arduino\code\2.26_photoresistordirectly.Or copy this code into Arduino IDE.
After uploading the codes to the Mega2560 board, you can open the serial monitor to see the read value of the pin. When the ambient light becomes stronger, the reading will increase correspondingly, and the pin reading range is ă0ă~ă1023ă. However, according to the environmental conditions and the characteristics of the photoresistor, the actual reading range may be smaller than the theoretical range. For a detailed explanation of the code, refer to 1.5 Analog Read.
Phenomenon Pictureï
