1.7 Analog Input Control Output
Overview
You can install an I/O system by using an analog input/ output device. For example, you can use potentiometer, photoresistor, water level sensor, etc., to control the brightness of LED, the speed of motor, and the like. In this lesson, potentiometer and LED are taken as examples to change the brightness of the LED when the potentiometer is turning.
Components Required
Fritzing Circuit
In this lesson, we use PWM pin 9 to drive LED. The analog pin (A0) is used to read the value of potentiometer. After uploading the code, you’ll notice that the brightness of the LED changes as the potentiometer rotates.
Schematic Diagram
You can open the file
1.7_analogInputControlOutput.inounder the path ofsunfounder_vincent_kit_for_arduino\code\1.7_analogInputControlOutputdirectly.Or copy this code into Arduino IDE.
When the codes are uploaded to the Mega2560 board, you can see that the brightness of LED is changing with the turning of the knob of potentiometer.
Code Analysis
Declare the pins of LED and Button.
const int sensorPin = A0;
const int ledPin = 9;
In setup(), set the mode of ledPin to OUTPUT.
pinMode(ledPin,OUTPUT);
Read the readings of potentiometer in loop().
int sensorValue=analogRead(sensorPin);
Map the potentiometer reading to the LED brightness value (0-1024 is mapped to 0-255).
int brightness = map(sensorValue,0,1024,0,255);
Write the brightness value to LED.
analogWrite(ledPin,brightness);
Phenomenon Picture
