2.21 Relay Module
Overview
In this lesson, you will learn about Relay Module.
Components Required
Fritzing Circuit
In this example, we use Power Supply Module to power the load,use LED as an example.
Schematic Diagram
You can open the file
2.21_relayModule.inounder the path ofsunfounder_vincent_kit_for_arduino\code\2.21_relayModuledirectly.Or copy this code into Arduino IDE.
Once the codes are uploaded to the Mega2560 board, you can see that the Relay Module controls the closing and breaking of the external circuit, which will change its working state a second. For detailed code explanation, refer to 1.2 Digital Write.
Phenomenon Picture
