2.4 LED Bar Graph
Overview
In this lesson, you will learn something about LED Bar Graph. Generally, LED Bar Graph works as a battery level indicator, Audio equipment, industrial control panel. If we want, we can also find its other application.
Components Required
Fritzing Circuit
In this example, we use digital pins 2~11 to drive the LED Bar Graph. LED Bar Graph has ten separate LEDs inside and each LED has two pins. The left pins 1~10 of LED Bar Graph are connected with the digital pins 2~11 respectively; the right side pins 11~20 are separately extended to same side of these 220ohm resistors whose other sides are identically connected to GND.
Schematic Diagram
You can open the file
2.4_ledBarGraph.inounder the path ofsunfounder_vincent_kit_for_arduino\code\2.4_ledBarGraphdirectly.Or copy this code into Arduino IDE.
Uploaded the codes to the Mega2560 board, you can see that the LEDs on the LED Bar Graph flash in sequence.
Code Analysis
The codes in setup() use the for loop to initialize pins 2~11 to output mode in turn.
for(int i=2;i<=11;i++)
pinMode(i,OUTPUT);
The for loop is used in loop() to make the LED flash(turn on 0.5s, then turn off 0.5s) in sequence.
digitalWrite(i,HIGH);
delay(500);
digitalWrite(i,LOW);
delay(500);
Refer to Part 1-1.2 Digital Write for more details about controlling the LED by using digital pins.
Phenomenon Picture
