πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
1.3 Analog Write
Overview
You can write the PWM wave to the pin by using analogWrite(). This method can be used to adjust the brightness of LED, change the color of RGB, or adjust the motor speed, etc. Here we will take LED as an example to get gradient brightness of LED.
Components Required
../_images/list_1.3.png
β€» Pulse Width Modulation
Pulse Width Modulation, or PWM, is a technique for getting analog results with digital means. Digital control is used to create a square wave, a signal switched between on and off. This on-off pattern can simulate voltages in between full on (5 Volts) and off (0 Volts) by changing the portion of the time the signal spends on versus the time that the signal spends off. The duration of β€œon time” is called the pulse width. To get varying analog values, you change, or modulate, that pulse width. If you repeat this on-off pattem fast enough with an LED for example, the result is as if the signal is a steady voltage between 0 and 5v controlling the brightness of the LED.
A call to analogWrite() is on a scale of 0 - 255, such that analogWrite(255) requests a 100% duty cycle (always on), and analogWrite(127) is a 50% duty cycle (on half the time) for example.
../_images/image402.png
Fritzing Circuit
In this example, we use the PWM pin 9 to drive the LED. Connect one end of the resistor to pin 9. Connect the long pin (anode) of the LED to the other end of the resistor. Connect the short pin (negative, referred to as the cathode) of LED to GND.
PWM pins of Mega2560 board are 2 -13, 44 - 46.
../_images/image30.png
Schematic Diagram
../_images/image401.png
Code
  • You can open the file 1.3_analogWrite.ino under the path of sunfounder_vincent_kit_for_arduino\code\1.3_analogWrite directly.
After uploading the code to the Mega2560 board, you can see that the LED gradually brightens out and turns off gradually.
Code Analysis
Declare pin 9 as ledPin.
int ledPin = 9;
analogWrite() in loop() assigns ledPin an analog value (PWM wave) between 0 and 255 to change the brightness of LED.
analogWrite(ledPin, value);
Using a for loop, the value of analogWrite() can be changed step by step between the minimum value (0) and the maximum value (255).
for (int value = 0 ; value <= 255; value += 5) {
In order to see the experimental phenomenon clearly, a delay(30) needs to be added to the for cycle to control the brightness change time.
    delay(30);
Phenomenon Picture
../_images/image36.jpeg
