2.28 Sound Sensor Moduleο
Overviewο
In this lesson, you will learn how to use a sound sensor module. The sound sensor module provides an easy way to detect sound and is generally used for detecting sound intensity.
Components Requiredο
Fritzing Circuitο
In this example, we can directly connect the pin of Sound Sensor Module to the pin of Mega 2560 Board, connect the pinγGγ of Sound Sensor Module to GND, the pin γ+γto 5V, AO to analog pin A0, and D0 to digital pin 2.
Schematic Diagramο
Codeο
You can open the file
2.28_soundSensorModule.inounder the path ofsunfounder_vincent_kit_for_arduino\code\2.28_soundSensorModuledirectly.Or copy this code into Arduino IDE.
After uploading the code to the Mega2560 board, you can open the serial monitor to see the read value of the pin. When the ambient sound gets louder, the digital reading is γ1γ (adjust the potentiometer of the module to modify the threshold to trigger the high level), and the reading value of the analog pin will change significantly; when the environment is quiet, the digital reading is γ0γ and the analog reading changes smoothly.
The range of analog reading isγ0γ~γ1023γ, but influenced by the the environmental condition and the characteristics of sound sensor, the actual reading range may be smaller than the theoretical one. If an oscilloscope is used, the changing of analog reading of the sound sensor will be more obvious.
About the detail code explanation, refer to 1.5 Analog Read and 1.4 Digital Read.
Phenomenon Pictureο
