SunFounder vincent_kit_for_arduino
latest
  • About this Kit
  • Components List and Introduction
  • Play with Arduino
    • 1.1 Get Started with Arduino IDE
    • 1.2 Digital Write
    • 1.3 Analog Write
    • 1.4 Digital Read
    • 1.5 Analog Read
    • 1.6 Digital Input Control Output
    • 1.7 Analog Input Control Output
    • 1.8 Serial Read
    • 1.9 Digital Input Pull-Up
    • 1.10 State Change Detection
    • 1.11 Interval
    • 2.2 LED
    • 2.3 RGB LED
    • 2.4 LED Bar Graph
    • 2.5 7-Segment Display
    • 2.6 74HC595
    • 2.7 4-Digital 7-Segment Display
    • 2.8 LED Matrix Module
    • 2.9 I2C LCD1602 Module
    • 2.10 Active Buzzer
    • 2.11 Passive Buzzer
    • 2.12 Servo
    • 2.13 Motor
    • 2.14 Stepper Motor
    • 2.15 Button
    • 2.16 Slide Switch
    • 2.17 Tilt Switch
    • 2.18 Touch Switch Module
    • 2.19 Keypad
    • 2.20 IR Receiver Module
    • 2.21 Relay Module
    • 2.22 Potentiometer
    • 2.23 Joystick Module
    • 2.24 MPR121 Module
    • 2.25 Rotary Encoder Module
    • 2.26 Photoresistor
    • 2.27 Thermistor
    • 2.28 Sound Sensor Module
    • 2.29 Water Sensor Module
    • 2.30 IR Obstacle Avoidance Sensor
    • 2.31 PIR Module
    • 2.32 DHT11 Module
    • 2.33 Ultrasonic Module
    • 2.34 MPU6050 Module
    • 2.35 RFID-RC522 Module
    • 3.1 Reversing Aid
    • 3.2 Pedestrian Crossing Button
    • 3.3 Overheat Monitor
    • 3.4 Guess Number
    • 3.5 Access Control System
  • Play with Scratch
  • Thank You
  • Play with Arduino
  • Edit on GitHub
Play with ArduinoΒΆ
1. Basic
  • 1.2 Digital Write
  • 1.3 Analog Write
  • 1.4 Digital Read
  • 1.5 Analog Read
  • 1.8 Serial Read
  • 1.11 Interval
2. Projects for Each Component
  • 2.2 LED
  • 2.3 RGB LED
  • 2.4 LED Bar Graph
  • 2.6 74HC595
  • 2.12 Servo
  • 2.13 Motor
  • 2.15 Button
  • 2.16 Slide Switch
  • 2.17 Tilt Switch
  • 2.19 Keypad
  • 2.21 Relay Module
  • 2.27 Thermistor
  • 2.31 PIR Module
  • 2.32 DHT11 Module
3.Funny Projects
  • 3.1 Reversing Aid
  • 3.4 Guess Number
Previous Next
© Copyright 2023, SunFounder. Revision a819c624.
Built with Sphinx using a theme provided by Read the Docs.
Read the Docs v: latest
Versions
latest
Downloads
pdf
html
epub
On Read the Docs
Project Home
Builds
