2.6 74HC595
Overview
In this lesson, you will learn how to use 74HC595. 74HC595 consists of an 8−bit shift register and a storage register with three−state parallel outputs. It converts serial input into parallel output so you can save IO ports of an MCU.
Components Required
../_images/list_2.6.png
Fritzing Circuit
../_images/image433.png
In this example, we use 74HC595 to control LED. Give each data output pin(Q0-Q7)a 220 ohm resistor then connect them to LED. The wiring diagram is as follows:
../_images/image434.png
Schematic Diagram
../_images/image435.png
  • You can open the file 2.6_74HC595.ino under the path of sunfounder_vincent_kit_for_arduino\code\2.6_74HC595 directly.
When you finish uploading the codes to the Mega2560 board, you can see the LEDs turning on one after another.
Code Analysis
Declare an array, store several 8 bit binary numbers that are used to change the working state of the eight LEDs controlled by 74HC595.
int datArray[] = {B00000000, B00000001, B00000011, B00000111, B00001111, B00011111, B00111111, B01111111, B11111111};
Set STcp to low level first and then high level. It will generate a rising edge pulse of STcp.
digitalWrite(STcp,LOW);
shiftOut() is used to shift out a byte of data one bit at a time, which means to shift a byte of data in datArray[num] to the shifting register with the DS pin. MSBFIRST means to move from high bits.
shiftOut(DS,SHcp,MSBFIRST,datArray[num]);
After digitalWrite(STcp,HIGH) is run, the STcp will be at the rising edge. At this time, the data in the shift register will be moved to the memory register.
digitalWrite(STcp,HIGH);
A byte of data will be transferred into the memory register after 8 times. Then the data of memory register are output to the bus (Q0-Q7). For example, shiftout「B00000001」will light up the LED controlled by Q0 and turn off the LED controlled by Q1~Q7.
Phenomenon Picture
../_images/image95.jpeg
