SunFounder Mega Board
The SunFounder Mega board is a mainboard with almost the same functions as the Arduino Mega 2560 Rev3, and the two boards can be used interchangeably.
The SunFounder Mega Board is a microcontroller board based on the ATmega2560 (datasheet). It has 54 digital input/output pins (of which 15 can be used as PWM outputs), 16 analog inputs, 4 UARTs (hardware serial ports), a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. The SunFounder Mega Board board is compatible with most shields designed for the Uno and the former boards Duemilanove or Diecimila.
Technical Parameters
MICROCONTROLLER: ATmega2560
OPERATING VOLTAGE: 5V
INPUT VOLTAGE (RECOMMENDED): 7-12V
INPUT VOLTAGE (LIMIT): 6-20V
DIGITAL I/O PINS: 54 (0-53, of which 15 provide PWM output(2-13, 44-46))
ANALOG INPUT PINS: 16 (A0-A15)
DC CURRENT PER I/O PIN: 20 mA
DC CURRENT FOR 3.3V PIN: 50 mA
FLASH MEMORY: 256 KB of which 8 KB used by bootloader
SRAM: 8 KB
EEPROM: 4 KB
CLOCK SPEED: 16 MHz
LED_BUILTIN: 13
LENGTH: 101.52 mm
WIDTH: 53.3 mm
WEIGHT: 37 g
I2C Port: A4(SDA), A5(SCL); 20(SDA), 21(SCL)
What’s More
