1.10 State Change Detectionď
Overviewď
When you use button, you can not only press down the button, light on the LED, release the button, turn off the LED, but also can switch the working state of the LED every time the button is pressed. In order to achieve this effect, you need to know when the state of the button changes from off to on, that is, âstate change detectionâ. In this lesson, we will print the results of state change detection of the button in the serial monitor.
Components Requiredď
Fritzing Circuitď
In this example, we use pin 2 to read the signal of the button.
Schematic Diagramď
Codeď
You can open the file
1.10_stateChangeDetection.inounder the path ofsunfounder_vincent_kit_for_arduino\code\1.10_stateChangeDetectiondirectly.Or copy this code into Arduino IDE.
After the codes are uploaded into the Mega2560 board, the output number will switch between 0 and 1 every time you press the button.
Code Analysisď
Declare a pin connected to Button.
const int buttonPin = 2;
Declare a variable called ădetectionStateăto record every state of state change detection.
int detectionState = 0;
Declare two variables to read the state of the button for state change detection.
int buttonState = 0;
int lastButtonState = 0;
In setup(), initialize the pins and then start up the serial monitor.
pinMode(buttonPin, INPUT);
Serial.begin(9600);
In loop(), read the value of buttonPin and then assign to the variable buttonState.
buttonState = digitalRead(buttonPin);
Compare buttonState with lastButtonState, if they are not equal, it indicates that the state is changed. A delay(50) is needed to realize debouncing during the changing detection. After comparison, assign the buttonState to lastButtonState to make the next round of judgment.
if (buttonState != lastButtonState) {
delay(50);
lastButtonState = buttonState;
The state change judgment installed (buttonState != lastButtonState), the further judgment is made to get the conditionăPress the buttonă.
if (buttonState == HIGH) {
Under the stateăPress the buttonă, detectionState is being operated and it switches between 1 and 0. Meanwhile, the value of detectionState is printed.
detectionState=(detectionState+1)%2;
Serial.print("The detection state is:");
Serial.println(detectionState);
Phenomenon Pictureď
