πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.32 DHT11 Module
Overview
In this lesson, you will learn how to use DHT11 Module. The DHT11 is a basic, ultra low-cost digital temperature and humidity sensor. It uses a capacitive humidity sensor and a thermistor to measure the surrounding air, and spits out a digital signal on the data pin (no analog input pins are needed).
Components Required
../_images/Part_two_32.png
Fritzing Circuit
In this example, we can directly connect the pins of DHT11 Module to the pins of Mega 2560 Board, and we use pin 4 to read the signal of DHT11 Module. Connect the pinγ€Œ+」of DHT11 Module to 5V, the pinγ€Œ-」 to GND, and the pin OUT to pin 4.
../_images/image241.png
Wiring Diagram
../_images/image242.png
Code
  • You can open the file 2.32_dhtModule.ino under the path of sunfounder_vincent_kit_for_arduino\code\2.32_dhtModule directly.
  • The DHT sensor library library is used here, you can install it from the Library Manager.
    ../_images/lib_dht11.png
After the codes are uploaded to the Mega2560 board, the serial monitor will continue to output the current temperature and humidity values of the environment.
Code Analysis
  1. Includes the DHT.h library, which provides functions to interact with the DHT sensors. Then, set the pin and type for the DHT sensor.
    #include "DHT.h"
    #define DHTPIN 4  // Set the pin connected to the DHT11 data pin
    #define DHTTYPE DHT11 // DHT 11
    DHT dht(DHTPIN, DHTTYPE);
  2. Initializes serial communication at a baud rate of 115200 and initializes the DHT sensor.
        Serial.begin(115200);
        Serial.println("DHT11 test!");
        dht.begin();
  3. In the loop() function, read temperature and humidity values from the DHT11 sensor, and print them to the serial monitor.
        // Wait a few seconds between measurements.
        delay(2000);
        float humidity = dht.readHumidity();
        float temperture = dht.readTemperature();
        if (isnan(humidity) || isnan(temperture)) {
            return;
        // Print the humidity and temperature
        Serial.print("Humidity: ");
        Serial.print(humidity);
        Serial.print(" %\t");
        Serial.print("Temperature: ");
        Serial.print(temperture);
        Serial.println(" *C");
    • The dht.readHumidity() function is called to read the humidity value from the DHT sensor.
    • The dht.readTemperature() function is called to read the temperature value from the DHT sensor.
    • The isnan() function is used to check if the readings are valid. If either the humidity or temperature value is NaN (not a number), it indicates a failed reading from the sensor, and an error message is printed.
Phenomenon Picture
../_images/image243.jpeg
