Lesson 43: Plant Monitor
This project intelligently automates plant watering by triggering a water pump whenever the soil’s moisture level dips below a predetermined threshold. It also features an LCD display that showcases the temperature, humidity, and soil moisture levels, offering users valuable insights into the plant’s environmental conditions.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
The kit may contain different versions of the DHT11 module. Please confirm the wiring method according to the module you have.
To install the library, use the Arduino Library Manager and search for “LiquidCrystal I2C” and “DHT sensor library” and install it.
Code Analysis
The code is structured to seamlessly manage plant watering by monitoring environmental parameters:
Library Inclusions and Constants/Variables:
Incorporate
Wire.h,LiquidCrystal_I2C.h, andDHT.hlibraries for functionality. Specify pin assignments and settings for the DHT11 sensor, soil moisture sensor, and water pump.#include <Wire.h> #include <LiquidCrystal_I2C.h> #include <DHT.h> #define DHTPIN 14 // Digital pin for DHT11 sensor #define DHTTYPE DHT11 // DHT11 sensor type #define SOIL_MOISTURE_PIN 35 // Analog pin for soil moisture sensor #define WATER_PUMP_PIN 25 // Digital pin for water pump // Initialize sensor and LCD objects DHT dht(DHTPIN, DHTTYPE); LiquidCrystal_I2C lcd(0x27, 16, 2);
setup():Configure pin modes for the moisture sensor and pump. Initially deactivate the pump. Initialize and backlight the LCD. Activate the DHT sensor.
void setup() { // Set pin modes pinMode(SOIL_MOISTURE_PIN, INPUT); pinMode(WATER_PUMP_PIN, OUTPUT); // Initialize water pump as off digitalWrite(WATER_PUMP_PIN, LOW); // Initialize LCD and backlight lcd.init(); lcd.backlight(); // Start DHT sensor dht.begin(); }
loop():Measure humidity and temperature via the DHT sensor. Gauge soil moisture through the soil moisture sensor. Display the temperature and humidity on the LCD, then show soil moisture levels. Assess soil moisture to decide on water pump activation; if soil moisture is under 500 (adjustable threshold), run the pump for 1 second.
void loop() { // Read humidity and temperature from DHT11 float humidity = dht.readHumidity(); float temperature = dht.readTemperature(); // Read soil moisture level int soilMoisture = analogRead(SOIL_MOISTURE_PIN); // Display temperature and humidity on LCD lcd.clear(); lcd.setCursor(0, 0); lcd.print("Temp: " + String(temperature) + "C"); lcd.setCursor(0, 1); lcd.print("Humidity: " + String(humidity) + "%"); delay(2000); // Display soil moisture on LCD lcd.clear(); lcd.setCursor(0, 0); lcd.print("Soil Moisture: "); lcd.setCursor(0, 1); lcd.print(String(soilMoisture)); // Activate water pump if soil is dry if (soilMoisture > 650) { digitalWrite(WATER_PUMP_PIN, HIGH); // Turn on water pump delay(1000); // Pump water for 1 second digitalWrite(WATER_PUMP_PIN, LOW); // Turn off water pump } delay(2000); // Wait before next loop iteration }
