Lesson 31: Centrifugal Pump
In this lesson, you’ll learn how to control a centrifugal pump with an ESP32 Development Board and an L9110 motor control board. We’ll cover setting up and using two pins to operate the motor, causing the pump to spin in one direction for 5 seconds before shutting off. This project provides hands-on experience in managing motor operations and understanding digital signals in microcontroller programming, making it ideal for beginners in electronics and programming.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Code Analysis
Two pins are defined for controlling the motor, specifically
motorB_1AandmotorB_2A. These pins will connect to the L9110 motor control board to control the direction and speed of the motor.const int motorB_1A = 26; const int motorB_2A = 25;
Configuring the pins and controlling the motor:
The
setup()function initializes the pins asOUTPUTwhich means they can send signals to the motor control board.The
analogWrite()function is used to set the motor speed. Here, setting one pin toHIGHand the other toLOWmakes the pump spin in one direction. After a 5-second delay, both pins are set to 0, turning off the motor.
void setup() { pinMode(motorB_1A, OUTPUT); // set pump pin 1 as output pinMode(motorB_2A, OUTPUT); // set pump pin 2 as output analogWrite(motorB_1A, HIGH); analogWrite(motorB_2A, LOW); delay(5000);// wait for 5 seconds analogWrite(motorB_1A, 0); // turn off the pump analogWrite(motorB_2A, 0); }
