Lesson 25: Water Level Sensor Module
In this lesson, you’ll learn how to use an ESP32 Development Board for reading a water level sensor. We’ll cover continuously monitoring the sensor’s analog value and displaying it on the serial monitor. This project provides a great opportunity to grasp sensor integration and analog data reading with Arduino, making it ideal for beginners in electronics and microcontroller programming.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Code Analysis
Initializing the Sensor Pin:
Before using the water level sensor, it’s pin number is defined using a constant variable. This makes the code more readable and easier to modify.
const int sensorPin = 25;
Setting Up Serial Communication:
In the
setup()function, the baud rate for serial communication is set. This is crucial for the Arduino to communicate with the computer’s serial monitor.void setup() { Serial.begin(9600); // Start serial communication at 9600 baud rate }
Reading Sensor Data and Outputting to Serial Monitor:
The
loop()function continuously reads the sensor’s analog value usinganalogRead()and outputs it to the serial monitor usingSerial.println(). Thedelay(100)function makes the Arduino wait for 100 milliseconds before repeating the loop, controlling the rate of data reading and transmission.void loop() { Serial.println(analogRead(sensorPin)); // Read the analog value of the sensor and print it to the serial monitor delay(100); // Wait for 100 milliseconds }
