๐ Ready to explore and create with us? Click [here] and join today!
Centrifugal Pump๏
A centrifugal pump is a device that can move liquids from one place to another by using a rotating impeller. It can be used to pump water, oil, chemicals, etc. A centrifugal pump has two main parts: a motor and a pump. The motor provides power to the pump and the pump converts the rotational energy into pressure and flow.
Specification๏
Voltage Scope: DC 3 ~ 4.5V
Operating Current: 120 ~ 180mA
Power: 0.36 ~ 0.91W
Max Water Head: 0.35 ~ 0.55M
Max Flow Rate: 80 ~ 100 L/H
Continuous Working Life: 100 hours
Water Fing Grade: IP68
Driving Mode: DC, Magnetic Driving
Material: Engineering Plastic
Outlet Outside Diameter: 7.8 mm
Outlet Inside Diameter: 6.5 mm
It is a submersible pump and should be used that way. It tends to heat too much that thereโs a risk of overheating if you turn it on unsubmerged.
Example๏
Lesson 31: Centrifugal Pump (Arduino UNO)
Lesson 31: Centrifugal Pump (ESP32)
Lesson 31: Centrifugal Pump (Raspberry Pi Pico)
Lesson 31: Centrifugal Pump (Raspberry Pi)
Lesson 39: Automatic soap dispenser (Arduino UNO)
Lesson 45: Plant Monitor (Arduino UNO)
Lesson 43: Plant Monitor (ESP32)
