Lesson 29: Traffic Light Module
In this lesson, you’ll learn how to use an ESP32 Development Board to control a Mini Traffic Light Module. We’ll cover setting up the board and writing code to create a traffic light sequence: 5 seconds of green light, blinking yellow light for 1.5 seconds, and 5 seconds of red light. This project is ideal for beginners in electronics and programming as it provides practical experience with output operations and basic timing control using the ESP32.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Code Analysis
Before any operations, we define constants for the pins where LEDs are connected. This makes our code easier to read and modify.
const int rledPin = 25; //red const int yledPin = 26; //yellow const int gledPin = 27; //green
Here, we specify the pin modes for our LED pins. They are all set to
OUTPUTbecause we intend to send voltage to them.
void setup() { pinMode(rledPin, OUTPUT); pinMode(yledPin, OUTPUT); pinMode(gledPin, OUTPUT); }
This is where our traffic light cycle logic is implemented. The sequence of operations is:
Turn the green LED on for 5 seconds.
Blink the yellow LED three times (each blink lasts for 0.5 seconds).
Turn the red LED on for 5 seconds.
void loop() { digitalWrite(gledPin, HIGH); delay(5000); digitalWrite(gledPin, LOW); digitalWrite(yledPin, HIGH); delay(500); digitalWrite(yledPin, LOW); delay(500); digitalWrite(yledPin, HIGH); delay(500); digitalWrite(yledPin, LOW); delay(500); digitalWrite(yledPin, HIGH); delay(500); digitalWrite(yledPin, LOW); delay(500); digitalWrite(rledPin, HIGH); delay(5000); digitalWrite(rledPin, LOW); }
