Power Supply Module
The breadboard power module provides 3.3V and 5V with a series diode and reverse polarity protection. It accepts input from 6.5V to 12V and outputs 3.3V and +5V. This power supply module is essential for experimenters who need to test electronic circuits on breadboards or perforated/veroboards.
Features
Plug directly to MB102 Standard breadboard.
Input voltage: 6.5-12 V (DC) or 5V USB power supply.
Output voltage: 3.3V and 5V can switch over.
Maximum output current: <700 mA.
External Input voltage ON/OFF switch.
Independent control of upper and Lower Bread Board Power Rails. Can switch over to 0V, 3.3V, 5V using jumpers on any rail.
On-board two groups of 3.3V, 5V DC output plug pin, convenient external lead use.
USB device connector onboard for power output to external device.
Size: 5.3cm x 3.5cm.
Example
Lesson 39: Automatic soap dispenser (Arduino UNO)
Lesson 45: Plant Monitor (Arduino UNO)
Lesson 43: Plant Monitor (ESP32)
