Lesson 22: Touch Sensor Module
In this lesson, you’ll learn how to use a touch sensor with an ESP32 Development Board. We’ll see how touching the sensor sends a signal to the ESP32, triggering a response displayed through serial communication. This project is ideal for beginners and provides hands-on experience with digital inputs and serial output on the ESP32 platform. You’ll develop a foundational understanding of how sensors interact with microcontrollers, which is essential for building interactive hardware projects.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
ESP32 & Development Board (ESP32 Board)
Touch Sensor Module
../_images/Lesson_22_Touch_Sensor_Module_esp32_bb.png
Code Analysis
  1. Setting Up the Pin and Serial Communication
    • The touch sensor is connected to pin 25 of the ESP32, and this pin is configured as an input.
    • The Serial.begin(9600); initializes serial communication at a baud rate of 9600 bits per second.
    const int sensorPin = 25;
      pinMode(sensorPin, INPUT);     // Set the sensor pin as input
      Serial.begin(9600);            // Start the serial communication
  2. Reading the Sensor and Sending Data to Serial Monitor
    • The loop() function continuously checks the state of the touch sensor.
    • digitalRead(sensorPin) reads the digital value (1 or 0) from the sensor pin.
    • If the sensor is touched (value 1), it prints “Touch detected!” to the Serial Monitor.
    • If not touched (value 0), it prints “No touch detected…”.
    • The delay(100); helps in debouncing the sensor, preventing multiple rapid readings.
      if (digitalRead(sensorPin) == 1) {  // If the sensor is touched
        Serial.println("Touch detected!");
      } else {
        Serial.println("No touch detected...");
      delay(100);  // Wait for a short period to avoid rapid reading of the sensor
