Lesson 18: Temperature Sensor Module (DS18B20)
In this lesson, you will learn how to read temperature data from a DS18B20 temperature sensor module using an ESP32 Development Board. We’ll use the DallasTemperature library to interface with the sensor and display temperature readings in both Celsius and Fahrenheit units on the Serial Monitor.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
To install the library, use the Arduino Library Manager and search for “DallasTemperature” and install it.
Code Analysis
Library inclusion
The inclusion of the OneWire and DallasTemperature libraries allows communication with the DS18B20 sensor.
#include <OneWire.h> #include <DallasTemperature.h>
Defining the sensor data pin
The DS18B20 is connected to digital pin 25 of the Arduino.
#define ONE_WIRE_BUS 25Initializing the sensor
The OneWire instance and DallasTemperature object are created and initialized.
OneWire oneWire(ONE_WIRE_BUS); DallasTemperature sensors(&oneWire);
Setup function
The
setup()function initializes the sensor and sets up serial communication.void setup(void) { sensors.begin(); // Start up the library Serial.begin(9600); }
Main loop
In the
loop()function, the program requests temperature readings and prints them in both Celsius and Fahrenheit.void loop(void) { sensors.requestTemperatures(); Serial.print("Temperature: "); Serial.print(sensors.getTempCByIndex(0)); Serial.print("℃ | "); Serial.print((sensors.getTempCByIndex(0) * 9.0) / 5.0 + 32.0); Serial.println("℉"); delay(500); }
