Lesson 24: Vibration Sensor Module (SW-420)
In this lesson, you’ll learn how to detect vibrations using an ESP32 Development Board and a Vibration Sensor (SW-420). We’ll cover reading digital output from the sensor and using conditional statements to display messages on the serial monitor. When the sensor detects vibration, it will display “Detected vibration…”; otherwise, it will output “…”. This project provides a practical way to grasp digital inputs and serial communication, making it ideal for electronics and programming beginners.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
ESP32 & Development Board (ESP32 Board)
../_images/Lesson_24_Vibration_Sensor_Module_esp32_bb.png
Code Analysis
  1. The first line of code is a constant integer declaration for the vibration sensor pin. We use digital pin 25 to read the output from the vibration sensor.
    const int sensorPin = 25;
  2. In the setup() function, we initialize the serial communication at a baud rate of 9600 to print readings from the vibration sensor to the serial monitor. We also set the vibration sensor pin as an input.
      Serial.begin(9600);         // Start serial communication at 9600 baud rate
      pinMode(sensorPin, INPUT);  // Set the sensorPin as an input pin
  3. The loop() function is where we continuously check for any vibrations detected by the sensor. If the sensor detects a vibration, it prints “Detected vibration…” to the serial monitor. If no vibration is detected, it prints “…”. The loop repeats every 100 milliseconds.
      if (digitalRead(sensorPin)) {               // Check if there is any vibration detected by the sensor
        Serial.println("Detected vibration...");  // Print "Detected vibration..." if vibration detected
      else {
        Serial.println("...");  // Print "..." otherwise
      // Add a delay to avoid flooding the serial monitor
      delay(100);
