š Ready to explore and create with us? Click [here] and join today!
Lesson 07: Infrared Speed Sensor Moduleļ
In this lesson, youāll learn how to use an ESP32 Development Board with a Speed Sensor Module to detect obstructions. Weāll see how the sensor sends a high signal when thereās an obstruction and a low signal when the path is clear. This project is ideal for those looking to grasp sensor integration and basic input/output operations in a practical setting using the ESP32 platform.
Required Componentsļ
Itās definitely convenient to buy a whole kit, hereās the link:
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Wiringļ
Codeļ
Code Analysisļ
Define the sensor pin
The sensor pin is declared as a constant integer and is assigned pin number 25 of the ESP32.
const int sensorPin = 25;
Setup function
This function initializes the serial communication at 9600 baud rate and sets the sensorPin as an input.
void setup() { Serial.begin(9600); pinMode(sensorPin, INPUT); }
Loop function
The loop function continuously checks the sensor pinās status. If the sensor pin reads HIGH, it prints āObstruction detectedā to the Serial Monitor. If the sensor pin is LOW, it prints āUnobstructedā.
void loop() { if (digitalRead(sensorPin) == HIGH) { Serial.println("Obstruction detected"); } else { Serial.println("Unobstructed"); } }
More
If an encoder is mounted on the motor, the rotational speed of the motor can be calculated by counting the number of times an obstruction passes the sensor within a specific period.
