Lesson 03: Flame Sensor Module
In this lesson, you will learn how to connect a flame sensor to an ESP32 Development Board for fire detection. We’ll examine the sensor’s response to fire and how it triggers a warning message. This project is ideal for beginners working with sensors and ESP32, providing hands-on experience in monitoring environmental factors using basic electronic components.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Code Analysis
Defining the Sensor Pin:
The pin to which the flame sensor is connected is defined as an integer constant.
const int sensorPin = 25;
Setup Function:
This function runs once when the ESP32 starts. It initializes the sensor pin as an input and begins serial communication at 9600 baud rate for output.
void setup() { pinMode(sensorPin, INPUT); Serial.begin(9600); }
Loop Function:
The core of the program, it continuously checks the state of the flame sensor. If the sensor detects a flame (returns 0), it prints a fire alert message. Otherwise, it indicates no fire is detected. The check happens every 100 milliseconds.
void loop() { if (digitalRead(sensorPin) == 0) { Serial.println("** Fire detected!!! **"); } else { Serial.println("No Fire detected"); } delay(100); }
