Lesson 09: Joystick Module
In this lesson, you will learn how to read values from a joystick module using the ESP32 Development Board. We’ll cover measuring the X and Y axis movements of the joystick and interpreting the switch position. By integrating these inputs with the ESP32, you’ll gain insights into handling analog and digital signals. This project is perfect for beginners, providing hands-on experience in reading and processing data from interactive hardware components.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
ESP32 & Development Board (ESP32 Board)
Joystick Module
../_images/Lesson_09_Jostick_Module_esp32_bb.png
Code Analysis
  1. Pin Definitions:
    const int xPin = 27;  //the VRX attach to
    const int yPin = 26;  //the VRY attach to
    const int swPin = 25;  //the SW attach to
    Constants for the joystick pins are defined. xPin and yPin are analog pins for the joystick’s X and Y axes. swPin is a digital pin for the joystick’s switch.
  2. Setup Function:
      pinMode(swPin, INPUT_PULLUP);
      Serial.begin(9600);
    Initializes swPin as an input with a pull-up resistor, essential for the switch’s functionality. Starts serial communication at 9600 baud.
  3. Main Loop:
      Serial.print("X: ");
      Serial.print(analogRead(xPin));  // print the value of VRX
      Serial.print("|Y: ");
      Serial.print(analogRead(yPin));  // print the value of VRY
      Serial.print("|Z: ");
      Serial.println(digitalRead(swPin));  // print the value of SW
      delay(50);
    Continuously reads and prints the values from the joystick’s axes and switch to the Serial Monitor, with a delay of 50 ms between readings.
