Lesson 11: Photoresistor Module
In this lesson, you will learn how to use a photoresistance sensor with an ESP32 Development Board to measure light intensity. We’ll explore how the sensor detects different light levels and processes and displays these readings on the serial monitor. This project is ideal for beginners as it provides hands-on experience with analog sensors and real-time data handling in Arduino programming.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Code Analysis
Setting Up the Sensor Pin and Serial Communication
We start by defining the sensor pin and initializing serial communication in the setup function. The photoresistor is connected to the pin 25.
const int sensorPin = 25; // Pin connected to the photoresistor void setup() { Serial.begin(9600); // Start serial communication at 9600 baud rate }
Reading and Displaying Sensor Data
In the loop function, we continuously read the analog value from the sensor and print it to the Serial Monitor. We also add a short delay to stabilize the readings.
void loop() { Serial.println(analogRead(sensorPin)); // Read and print the analog value delay(50); // Short delay to stabilize readings }
