πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
Lesson 40: Touch toggle light
This project is a simple implementation of a traffic light control system utilizing a touch sensor and a traffic light LED module. Activating the touch sensor initiates a sequence where LEDs illuminate in the following order: Red -> Yellow -> Green.
Required Components
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
ESP32 & Development Board (ESP32 Board)
Touch Sensor Module
Traffic Light Module
Wiring
../_images/Lesson_40_Touch_toggle_light_esp32_bb.png
Code
Code Analysis
The operation of this project is straightforward: a touch detection on the sensor triggers the illumination of the next LED in the sequence (Red -> Yellow -> Green), controlled by the currentLED variable.
  1. Define pins and initial values
    // Define pins for touch sensor and LEDs
    const int touchSensorPin = 14;  // touch sensor pin
    const int rledPin = 27;         // red LED pin
    const int yledPin = 26;         // yellow LED pin
    const int gledPin = 25;         // green LED pin
    int lastTouchState;     // the previous state of touch sensor
    int currentTouchState;  // the current state of touch sensor
    int currentLED = 0;     // current LED 0->Red, 1->Yellow, 2->Green
    These lines establish the pin connections for the Arduino board components and initialize the touch sensor and LED states.
  2. setup() function
      Serial.begin(9600);              // initialize serial
      pinMode(touchSensorPin, INPUT);  // configure touch sensor pin as input
      // set LED pins as outputs
      pinMode(rledPin, OUTPUT);
      pinMode(yledPin, OUTPUT);
      pinMode(gledPin, OUTPUT);
      currentTouchState = digitalRead(touchSensorPin);
    This function configures the initial setup for the Arduino, defining input and output modes and starting serial communication for debugging.
  3. loop() function
      lastTouchState = currentTouchState;               // save the last state
      currentTouchState = digitalRead(touchSensorPin);  // read new state
      // check if the touch sensor was just touched
      if (lastTouchState == LOW && currentTouchState == HIGH) {
        Serial.println("The sensor is touched");
        turnAllLEDsOff();  // Turn off all LEDs
        // switch on the next LED in sequence
        switch (currentLED) {
          case 0:
            digitalWrite(rledPin, HIGH);
            currentLED = 1;
            break;
          case 1:
            digitalWrite(yledPin, HIGH);
            currentLED = 2;
            break;
          case 2:
            digitalWrite(gledPin, HIGH);
            currentLED = 0;
            break;
    The loop continuously monitors the touch sensor, cycling through the LEDs when a touch is detected, ensuring only one LED is on at any given time.
  4. Turn off LEDs function
    // function to turn off all LEDs
    void turnAllLEDsOff() {
      digitalWrite(rledPin, LOW);
      digitalWrite(yledPin, LOW);
      digitalWrite(gledPin, LOW);
    This auxiliary function turns off all LEDs, aiding in the cycling process.
