Lesson 13: Potentiometer Module
In this lesson, you’ll learn how to read the analog value of a potentiometer with the ESP32 development board. We’ll connect a potentiometer module to pin 25 and observe the changing analog values (0-4095) in the serial monitor. This project provides hands-on experience in understanding analog inputs and serial communication, making it an excellent exercise for beginners to explore the capabilities of the ESP32 board.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Code Analysis
This line of code defines the pin number to which the potentiometer is connected on the ESP32 Development Board.
const int sensorPin = 25;
The
setup()function is a special function in Arduino that is executed only once when the ESP32 Development Board is powered on or reset. In this project, theSerial.begin(9600)command initiates serial communication at a baud rate of 9600.void setup() { Serial.begin(9600); }
The
loop()function is the main function where the program runs repeatedly. In this function, theanalogRead()function reads the analog value from the potentiometer and prints it to the serial monitor usingSerial.println(). Thedelay(50)command makes the program wait for 50 milliseconds before taking the next reading.void loop() { Serial.println(analogRead(sensorPin)); delay(50); }
