Lesson 23: Ultrasonic Sensor Module (HC-SR04)
In this lesson, you’ll learn how to use an ESP32 Development Board for measuring distance with an ultrasonic sensor (HC-SR04). We’ll cover setting up the sensor, reading data, and calculating the distance in centimeters. This project is ideal for beginners working with microcontrollers and sensors, offering hands-on experience in data acquisition and serial communication. You’ll develop practical skills in programming the ESP32 and grasp ultrasonic sensing technology.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Code Analysis
Pin declaration:
Start by defining the pins for the ultrasonic sensor.
echoPinandtrigPinare declared as integers and their values are set to match the physical connection on the ESP32 Development Board.const int echoPin = 26; const int trigPin = 25;
setup()function:The
setup()function initializes the serial communication, sets the pin modes, and prints a message to indicate the ultrasonic sensor is ready.void setup() { Serial.begin(9600); pinMode(echoPin, INPUT); pinMode(trigPin, OUTPUT); Serial.println("Ultrasonic sensor:"); }
loop()function:The
loop()function reads the distance from the sensor and prints it to the serial monitor, then delays for 400 milliseconds before repeating.void loop() { float distance = readDistance(); Serial.print(distance); Serial.println(" cm"); delay(400); }
readDistance()function :The
readDistance()function triggers the ultrasonic sensor and calculates the distance based on the time it takes for the signal to bounce back.For more details, please refer to the working principle of the ultrasonic sensor module.
float readDistance() { digitalWrite(trigPin, LOW); // Set trig pin to low to ensure a clean pulse delayMicroseconds(2); // Delay for 2 microseconds digitalWrite(trigPin, HIGH); // Send a 10 microsecond pulse by setting trig pin to high delayMicroseconds(10); digitalWrite(trigPin, LOW); // Set trig pin back to low float distance = pulseIn(echoPin, HIGH) / 58.00; // Formula: (340m/s * 1us) / 2 return distance; }
