Lesson 30: Relay Module
In this lesson, you’ll learn how to use an ESP32 Development Board to control a one-channel relay module. We’ll cover turning the relay on and off in a loop, with a 3-second delay between each state change. This project provides hands-on experience with digital output operations in embedded systems, making it ideal for beginners entering the realm of ESP32 and relay modules.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
ESP32 & Development Board (ESP32 Board)
5V Relay Module
RGB LED Module
../_images/Lesson_30_Relay_esp32_bb.png
Code Analysis
  1. Setting up the relay pin:
    • The relay module is connected to pin 25 of the ESP32 Development Board. This pin is defined as relayPin for ease of reference in the code.
    const int relayPin = 25;
  2. Configuring the relay pin as an output:
    • In the setup() function, the relay pin is set as an OUTPUT using the pinMode() function. This means the Arduino will send signals (either HIGH or LOW) to this pin.
      pinMode(relayPin, OUTPUT);
  3. Toggling the relay ON and OFF:
    • In the loop() function, the relay is first set to the OFF state using digitalWrite(relayPin, LOW). It remains in this state for 3 seconds (delay(3000)).
    • Then, the relay is set to the ON state using digitalWrite(relayPin, HIGH). Again, it remains in this state for 3 seconds.
    • This cycle repeats indefinitely.
      digitalWrite(relayPin, LOW);
      delay(3000);
      digitalWrite(relayPin, HIGH);
      delay(3000);
