Lesson 12: PIR Motion Module (HC-SR501)
In this lesson, you will learn how to use a PIR (Passive Infrared) motion sensor with an ESP32 Development Board. You’ll learn how to read digital inputs from the sensor to detect motion and output a corresponding message to the serial monitor. We’ll cover the setup and programming required for the ESP32 board to respond when the sensor detects someone’s presence by displaying “Somebody here!”
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Code Analysis
Setting up the PIR Sensor Pin. The pin for the PIR sensor is defined as pin 25.
const int pirPin = 25; int state = 0;
Initializing the PIR Sensor. In the
setup()function, the PIR sensor pin is set as an input. This allows the Arduino to read the state of the PIR sensor.void setup() { pinMode(pirPin, INPUT); Serial.begin(9600); }
Reading from the PIR Sensor and Displaying the Results. In the
loop()function, the state of the PIR sensor is continuously read.void loop() { state = digitalRead(pirPin); if (state == HIGH) { Serial.println("Somebody here!"); } else { Serial.println("Monitoring..."); delay(100); } }
If the state is
HIGH, meaning motion is detected, a message “Somebody here!” is printed to the serial monitor. Otherwise, “Monitoring…” is printed.
