š Ready to explore and create with us? Click [here] and join today!
Lesson 05: Gyroscope & Accelerometer Module (MPU6050)ļ
In this lesson, you will learn how to connect the MPU6050 accelerometer and gyroscope sensor to an ESP32 Development Board. We will go through setting up the Adafruit_MPU6050 library, initializing the sensor, and configuring its accelerometer and gyro ranges. Youāll also learn how to read acceleration, rotation, and temperature data from the sensor and display these values on the serial monitor. This project is ideal for those interested in exploring motion tracking and orientation sensing in their projects, providing a practical experience in working with advanced sensors on the Arduino-compatible ESP32 platform.
Required Componentsļ
Itās definitely convenient to buy a whole kit, hereās the link:
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Wiringļ
Codeļ
To install the library, use the Arduino Library Manager and search for āAdafruit MPU6050ā and install it.
Code Analysisļ
The code starts by including the necessary libraries and creating an object for the MPU6050 sensor. This code uses the Adafruit_MPU6050 library, Adafruit_Sensor library, and Wire library. The
Adafruit_MPU6050library is used to interact with the MPU6050 sensor and retrieve acceleration, rotation, and temperature data. TheAdafruit_Sensorlibrary provides a common interface for various types of sensors. TheWirelibrary is used for I2C communication, which is necessary to communicate with the MPU6050 sensor.Note
#include <Adafruit_MPU6050.h> #include <Adafruit_Sensor.h> #include <Wire.h> Adafruit_MPU6050 mpu;
The
setup()function initializes the serial communication and checks if the sensor is detected. If the sensor is not found, the Arduino enters an infinite loop with a āFailed to find MPU6050 chipā message. If found, the accelerometer range, gyro range, and filter bandwidth are set, and a delay is added for stability.void setup(void) { // Initialize the serial communication Serial.begin(9600); // Check if the MPU6050 sensor is detected if (!mpu.begin()) { Serial.println("Failed to find MPU6050 chip"); while (1) { delay(10); } } Serial.println("MPU6050 Found!"); // set accelerometer range to +-8G mpu.setAccelerometerRange(MPU6050_RANGE_8_G); // set gyro range to +- 500 deg/s mpu.setGyroRange(MPU6050_RANGE_500_DEG); // set filter bandwidth to 21 Hz mpu.setFilterBandwidth(MPU6050_BAND_21_HZ); // Add a delay for stability delay(100); }
In the
loop()function, the program creates events to store the sensor readings and then retrieves the readings. The acceleration, rotation, and temperature values are then printed to the serial monitor.void loop() { // Get new sensor events with the readings sensors_event_t a, g, temp; mpu.getEvent(&a, &g, &temp); // Print out the acceleration, rotation, and temperature readings // ... // Add a delay to avoid flooding the serial monitor delay(1000); }
