Lesson 28: RGB LED Module
In this lesson, you will learn how to control an RGB LED using an ESP32 Development Board. We’ll cover using different color channels to display primary colors and creating a sequence of rainbow colors. This project is ideal for beginners in electronics and programming, providing hands-on experience with output operations and color mixing using the ESP32 and RGB LED module.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Code Analysis
The first segment of the code declares and initializes the pins to which each color channel of the RGB LED module is connected.
const int rledPin = 25; // pin connected to the red color channel const int gledPin = 26; // pin connected to the green color channel const int bledPin = 27; // pin connected to the blue color channel
The
setup()function initializes these pins as OUTPUT. This means we are sending signals OUT from these pins to the RGB LED module.void setup() { pinMode(rledPin, OUTPUT); pinMode(gledPin, OUTPUT); pinMode(bledPin, OUTPUT); }
In the
loop()function, thesetColor()function is called with different parameters to display different colors. Thedelay()function is used after setting each color to pause for 1000 milliseconds (or 1 second) before moving on to the next color.void loop() { setColor(255, 0, 0); // Set RGB LED color to red delay(1000); setColor(0, 255, 0); // Set RGB LED color to green delay(1000); // The rest of the color sequence... }
The
setColor()function uses theanalogWrite()function to adjust the brightness of each color channel on the RGB LED module. TheanalogWrite()function employs Pulse Width Modulation (PWM) to simulate varying voltage outputs. By controlling the PWM duty cycle (the percentage of time a signal is HIGH within a fixed period), the brightness of each color channel can be controlled, allowing the mixing of various colors.void setColor(int R, int G, int B) { analogWrite(rledPin, R); // Use PWM to control the brightness of the red color channel analogWrite(gledPin, G); // Use PWM to control the brightness of the green color channel analogWrite(bledPin, B); // Use PWM to control the brightness of the blue color channel }
