Lesson 34: TT Motor
In this lesson, you’ll learn how to control a motor with the ESP32 Development Board and an L9110 motor control board. We’ll cover defining and initializing motor pins, setting them as outputs, and adjusting the motor’s speed using the analogWrite function. This project is ideal for those seeking to grasp motor control and pulse-width modulation (PWM) on the ESP32 platform, providing a hands-on demonstration of output operations in a microcontroller environment.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
Code Analysis
The first part of the code defines the motor control pins. These are connected to the L9110 motor control board.
// Define the motor pins const int motorB_1A = 26; const int motorB_2A = 25;
The
setup()function initializes the motor control pins as output using thepinMode()function. Then it usesanalogWrite()to set the speed of the motor. The value passed toanalogWrite()can range from 0 (off) to 255 (full speed). Adelay()function is then used to pause the code for 5000 milliseconds (or 5 seconds), after which the motor speed is set to 0 (off).void setup() { pinMode(motorB_1A, OUTPUT); // set motor pin 1 as output pinMode(motorB_2A, OUTPUT); // set motor pin 2 as output analogWrite(motorB_1A, 255); // set motor speed (0-255) analogWrite(motorB_2A, 0); delay(5000); analogWrite(motorB_1A, 0); analogWrite(motorB_2A, 0); }
