Lesson 42: Digital Dice
This program simulates a dice roll using an OLED display. The simulation is triggered by shaking the vibration switch, causing the display to cycle through numbers 1 to 6, akin to rolling a dice. The display halts after a short duration, revealing a randomly selected number that represents the dice roll outcome.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
ESP32 & Development Board (ESP32 Board) |
To install the library, use the Arduino Library Manager and search for “Adafruit SSD1306” and “Adafruit GFX” and install it.
Code Analysis
A comprehensive breakdown of the code:
Initialization of variables:
vibPin: Digital pin connected to the vibration sensor.const int vibPin = 35; // The pin where the vib switch is connected
Volatile variables:
rolling: A volatile flag that indicates the dice’s rolling status. It is volatile as it is accessed within both the interrupt service routine and the main program.volatile bool rolling = false;
setup():Configures the vibration sensor’s input mode. Assigns an interrupt to the sensor to trigger the rollDice function upon state change. Initializes the OLED display.
void setup() { // Initialize pins pinMode(vibPin, INPUT); // initialize the OLED object if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) { Serial.println(F("SSD1306 allocation failed")); for (;;) ; } // Attach an interrupt to the vibPin. When the vib switch is activated, the shakeDetected function will be called attachInterrupt(digitalPinToInterrupt(vibPin), rollDice, CHANGE); }
loop():Continuously checks if
rollingis true, displaying a random number between 1 and 6 during this state. The rolling ceases if the sensor has been shaken for over 500 milliseconds.void loop() { // Check if it's rolling if (rolling) { byte number = random(1, 7); // Generate a random number between 1 and 6 displayNumber(number); delay(80); // Delay to make the rolling effect visible // Stop rolling after 1 second if ((millis() - lastShakeTime) > 1000) { rolling = false; } } }
rollDice():The interrupt service routine for the vibration sensor. It initiates the dice roll when the sensor is shaken by recording the current time.
// Interrupt handler for shake detection void rollDice() { if (digitalRead(vibPin) == LOW) { lastShakeTime = millis(); // Record the time of shake rolling = true; // Start rolling } }
displayNumber():Displays a selected number on the OLED screen.
// Function to display a number on the 7-segment display void displayNumber(byte number) { display.clearDisplay(); // Clear the screen // Display Text display.setTextSize(4); // Set text size display.setTextColor(WHITE); // Set text color display.setCursor(54, 20); // Set cursor position display.println(number); display.display(); // Display the content on the screen }
