Lesson 04: Gas Sensor Module (MQ-2)
In this lesson, you will learn how to measure gas concentrations using an MQ-2 sensor with an ESP32 Development Board. We’ll cover reading the analog output of the gas sensor and displaying it on the serial monitor. This project is ideal for beginners in electronics, providing hands-on experience with sensors and microcontrollers while teaching about analog signal processing and serial communication.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
ESP32 & Development Board (ESP32 Board)
Gas/Smoke Sensor Module (MQ2)
../_images/Lesson_04_MQ2_Module_esp32_bb.png
Code Analysis
  1. The first line of code is a constant integer declaration for the gas sensor pin. We use the pin 25 to read the output from the gas sensor.
    const int sensorPin = 25;
  2. The setup() function is where we initialize our serial communication at a baud rate of 9600. This is necessary to print the readings from the gas sensor to the serial monitor.
      Serial.begin(9600);  // Start serial communication at 9600 baud rate
  3. The loop() function is where we continuously read the analog value from the gas sensor and print it to the serial monitor. We use the analogRead() function to read the analog value from the sensor. We then wait for 50 milliseconds before the next reading. This delay gives some breathing space for the serial monitor to process the data.
    MQ2 is a heating-driven sensor that usually requires preheating before use. During the preheating period, the sensor typically reads high and gradually decreases until it stabilizes.
      Serial.print("Analog output: ");
      Serial.println(analogRead(sensorPin));  // Read the analog value of the gas sensor and print it to the serial monitor
      delay(50);                             // Wait for 50 milliseconds
