Configuring Your Raspberry Pi
I2C Configuration
To enable the I2C port on your Raspberry Pi, follow these steps (skip if already enabled; if unsure, proceed with the instructions).
Log into your Raspberry Pi, open the Terminal, and enter the command below to access the Raspberry Pi Software Configuration Tool. (You can also access the terminal using SSH.)
sudo raspi-config
Go to Interfacing options.
Use the
upanddownarrow keys to move the highlighted selection between the options available. Pressing therightarrow key will jump out of the Options menu and take you to the<Select>and<Finish>buttons. Pressingleftwill take you back to the options. Alternatively, you can use theTabkey to switch between these.
Select I2C.
Choose <Yes> to activate the I2C interface, then choose <Ok>.
Select <Finish> to exit the Raspberry Pi Software Configuration Tool.
Verify the address of the connected I2C device using the following command.
i2cdetect -y 1
Addresses of any connected I2C devices will be shown.
1-Wire Configuration
To enable the 1-Wire port on your Raspberry Pi, follow these steps (skip if already enabled; if unsure, proceed with the instructions).
Log into your Raspberry Pi, open the Terminal, and enter this command to access the Raspberry Pi Software Configuration Tool. (You can also access the terminal using SSH.)
sudo raspi-config
Use the
Select 1-Wire.
Choose <Yes> to activate the 1-Wire interface, then choose <Ok>.
Select <yes> to reboot the Raspberry Pi.
