Lesson 22: Touch Sensor Module
In this lesson, you will learn how to connect and program a touch sensor with the Raspberry Pi using Python. The focus will be on setting up the sensor on GPIO pin 17 and writing a simple script to detect and respond to touch and release events. This practical session is aimed at teaching the basics of sensor integration and event handling in Python, providing you with the skills needed for more advanced sensor-based projects. It’s an ideal starting point for those new to working with electronics and the Raspberry Pi.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from gpiozero import Button
from signal import pause
# Function called when the sensor is touched
def touched():
# Print a message indicating the sensor is touched
print("Touched!")
# Function called when the sensor is not touched
def not_touched():
# Print a message indicating the sensor is not touched
print("Not touched!")
# Initialize a Button object for the touch sensor
# GPIO 17: pin connected to the sensor
# pull_up=None: disable internal pull-up/pull-down resistors
# active_state=True: high voltage is considered the active state
touch_sensor = Button(17, pull_up=None, active_state=True)
# Assign functions to sensor events
touch_sensor.when_pressed = touched
touch_sensor.when_released = not_touched
pause() # Keep the program running to detect touch events
Code Analysis
Importing Libraries
The script starts by importing the
Buttonclass from gpiozero for interfacing with the touch sensor, andpausefrom the signal module to keep the program running and responsive to events.from gpiozero import Button from signal import pause
Defining Callback Functions
Two functions,
touchedandnot_touched, are defined to handle touch and release events from the sensor. Each function prints a message indicating the sensor’s state.def touched(): print("Touched!") def not_touched(): print("Not touched!")
Initializing the Touch Sensor
A
Buttonobject namedtouch_sensoris created for the touch sensor on GPIO pin 17. Thepull_upparameter is set toNoneto disable internal pull-up/pull-down resistors, andactive_stateis set toTrueto consider high voltage as the active state.touch_sensor = Button(17, pull_up=None, active_state=True)
Assigning Functions to Sensor Events
The
when_pressedevent of thetouch_sensoris linked to thetouchedfunction, and thewhen_releasedevent is linked to thenot_touchedfunction. This setup allows the script to react to touch and release events from the sensor.touch_sensor.when_pressed = touched touch_sensor.when_released = not_touched
Keeping the Program Running
The
pause()function is called to keep the program running indefinitely. This is necessary to continuously monitor and respond to touch sensor events.pause()
