Lesson 04: Gas Sensor Module (MQ-2)
In this lesson, you will learn to use the MQ2 gas sensor with Raspberry Pi for gas detection. The course covers connecting the MQ2 sensor to the GPIO17 pin and programming the Raspberry Pi in Python to read the sensor output. You’ll understand how to detect gas presence, with a low signal from the sensor indicating the detection of gas. This project offers a practical introduction to sensor usage and Python scripting on the Raspberry Pi, ideal for beginners interested in environmental monitoring and safety applications.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from gpiozero import DigitalInputDevice
# Initialize MQ2 sensor on GPIO17
mq2 = DigitalInputDevice(17)
# Detect gas presence (LOW signal indicates gas)
if mq2.value == 0:
print("Gas detected!")
print("No gas detected.")
# Delay between readings
time.sleep(1)
Code Analysis
Importing Libraries
from gpiozero import DigitalInputDevice import time
This section imports necessary libraries.
gpiozerois used for interacting with the GPIO pins of the Raspberry Pi, andtimeis used for handling time-related tasks such as delays.Initializing the MQ2 Sensor
Here, the MQ2 sensor is initialized as a digital input device on GPIO pin 17 of the Raspberry Pi. The
DigitalInputDeviceclass from gpiozero is used for this purpose.Infinite Loop for Sensor Reading
while True: if mq2.value == 0: print("Gas detected!") else: print("No gas detected.") time.sleep(1)
In this segment:
The DO pin on the MQ-2 sensor module indicates the presence of combustible gases. When the gas concentration exceeds the threshold value (as set by the potentiometer on the module), D0 becomes LOW; otherwise, it remains HIGH.
An infinite loop is created using
while True. This loop will continue to run until the program is manually stopped.Inside the loop, the value of the MQ2 sensor is checked using
mq2.value. If the value is 0, it indicates the presence of gas, and “Gas detected!” is printed. Otherwise, “No gas detected.” is printed.time.sleep(1)creates a delay of 1 second between each reading, reducing the frequency of the sensor checks and the output messages.
