Lesson 31: Centrifugal Pump
In this lesson, you will learn how to control a pump using a Raspberry Pi. You’ll learn how to write a Python script to activate the pump, control its speed, and then stop it after a set period. This project provides a basic understanding of pump control through GPIO interfacing and Python programming, making it a suitable starting point for beginners interested in Raspberry Pi and simple pump applications.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi 5
Centrifugal Pump
L9110 Motor Driver Module
../_images/Lesson_31_Pump_Pi_bb.png
from gpiozero import Motor
from time import sleep
# Define pump pins
pump = Motor(forward=17, backward=27)  # Using Raspberry Pi GPIO pin numbers
# Activate the pump
pump.forward(speed=1)  # Set pump speed, range is 0 to 1
sleep(5)               # Run the pump for 5 seconds
# Deactivate the pump
pump.stop()            # Stop the pump
Code Analysis
  1. Import Libraries
    The gpiozero library is used for controlling the motor, and the time library’s sleep function is for delays.
  2. Define Pump Pins
    A Motor object is created with two GPIO pins: one for forward and one for backward operation. In this case, GPIO 17 and 27 are used.
  3. Activate the pump
    The motor is activated in the forward direction with a specified speed using pump.forward(speed=1). The speed parameter ranges from 0 (stopped) to 1 (full speed). The motor runs for 5 seconds, as defined by sleep(5).
    sleep(5)
  4. Deactivate the pump
    The motor is stopped using pump.stop(). This is essential for safely halting the motor’s operation after the required duration.
    pump.stop()
