Lesson 12: PIR Motion Module (HC-SR501)
In this lesson, you will learn how to set up and use a motion sensor with the Raspberry Pi. We’ll walk you through connecting a digital motion sensor to GPIO pin 17. You’ll write a Python script to continually check the sensor’s state, printing a message when motion is detected and another when the area is clear. This hands-on tutorial is focused on practical skills in electronic circuitry and Python programming, making it perfect for beginners who want to explore real-world applications of the Raspberry Pi in monitoring and automation projects.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from gpiozero import DigitalInputDevice
from time import sleep
# Initialize the motion sensor as a digital input device on GPIO pin 17
motion_sensor = DigitalInputDevice(17)
# Continuously monitor the state of the motion sensor
if motion_sensor.is_active:
print("Somebody here!")
print("Monitoring...")
# Wait for 0.5 seconds before the next sensor check
sleep(0.5)
Code Analysis
Importing Libraries
The script starts by importing the
DigitalInputDeviceclass from the gpiozero library for interfacing with the motion sensor, and thesleepfunction from the time module to introduce delays.from gpiozero import DigitalInputDevice from time import sleep
Initializing the Motion Sensor
A
DigitalInputDeviceobject namedmotion_sensoris created, connected to GPIO pin 17. This assumes that the motion sensor is connected to this GPIO pin on the Raspberry Pi.motion_sensor = DigitalInputDevice(17)
Implementing Continuous Monitoring Loop
The script employs a
while True:loop for continuous monitoring.Inside the loop, an
ifstatement checks theis_activeproperty of themotion_sensor.If
is_activeisTrue, it suggests that motion is detected, and “Somebody here!” is printed.If
is_activeisFalse, suggesting no motion is detected, “Monitoring…” is printed.The
sleep(0.5)function is used to pause the loop for 0.5 seconds between each sensor check, reducing the processing demand and controlling the frequency of sensor polling.
while True: if motion_sensor.is_active: print("Somebody here!") else: print("Monitoring...") sleep(0.5)
