Lesson 27: OLED Display Module (SSD1306)
In this lesson, you will learn how to connect a Raspberry Pi with an OLED Display Module (SSD1306) using Python. You’ll learn how to establish I2C communication between the Raspberry Pi and the OLED display, and use the Python Imaging Library (PIL) for creating graphics and text. The lesson will guide you through drawing shapes and text on the OLED screen, providing a practical example with the message “Hello World!”.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi 5
../_images/Lesson_27_oled_pi_bb.png
Install Library
The adafruit-circuitpython-ssd1306 library relies on Blinka, so please ensure that Blinka has been installed. To install libraries, refer to Insatll Adafruit_Blinka (CircuitPython) - Optional.
Before installing the library, please make sure that the virtual Python environment is activated:
source ~/env/bin/activate
Install adafruit-circuitpython-ssd1306 library:
pip install adafruit-circuitpython-ssd1306
Run the Code
  • Please ensure that you have installed the Python library required for running the code according to the “Install Library” steps.
  • Before running the code, please make sure that you have activated the virtual Python environment with blinka installed. You can activate the virtual environment using a command like this:
  • Find the code for this lesson in universal-maker-sensor-kit-main/pi/ directory, or directly copy and paste the code below. Execute the code by running the following commands in terminal:
    python 27_ssd1306_oled_module.py
import board
import digitalio
from PIL import Image, ImageDraw, ImageFont
import adafruit_ssd1306
# Initialize OLED display dimensions
WIDTH = 128
HEIGHT = 64
# Set up I2C communication with the OLED display
i2c = board.I2C()  # Utilizes board's SCL and SDA pins
oled = adafruit_ssd1306.SSD1306_I2C(WIDTH, HEIGHT, i2c, addr=0x3C)
# Clear the OLED display
oled.fill(0)
oled.show()
# Create a new image with 1-bit color for drawing
image = Image.new("1", (oled.width, oled.height))
# Obtain a drawing object to manipulate the image
draw = ImageDraw.Draw(image)
# Draw a filled white rectangle as the background
draw.rectangle((0, 0, oled.width, oled.height), outline=255, fill=255)
# Define border size for an inner rectangle
BORDER = 5
# Draw a smaller black rectangle inside the larger one
draw.rectangle(
    (BORDER, BORDER, oled.width - BORDER - 1, oled.height - BORDER - 1),
    outline=0,
    fill=0,
# Load the default font for text
font = ImageFont.load_default()
def getfontsize(font, text):
    # Calculate the size of the text in pixels
    left, top, right, bottom = font.getbbox(text)
    return right - left, bottom - top
# Define the text to be displayed
text = "Hello World!"
# Get the width and height of the text in pixels
(font_width, font_height) = getfontsize(font, text)
# Draw the text, centered on the display
draw.text(
    (oled.width // 2 - font_width // 2, oled.height // 2 - font_height // 2),
    text,
    font=font,
    fill=255,
# Send the image to the OLED display
oled.image(image)
oled.show()
Code Analysis
  1. Importing Necessary Libraries
    Here, we import the libraries needed for the project. board is for interfacing with the Raspberry Pi hardware, PIL for image processing, and adafruit_ssd1306 for controlling the OLED display.
    For more detail about the adafruit_ssd1306 library, please refer to adafruit/Adafruit_CircuitPython_SSD1306.
    import board
    import digitalio
  2. Initializing the OLED Display
    The OLED display dimensions are set, and I2C communication is established. The adafruit_ssd1306.SSD1306_I2C object is created to interact with the OLED.
    WIDTH = 128
    HEIGHT = 64
    i2c = board.I2C()
  3. Clearing the Display
    The OLED display is cleared by filling it with zeros (black).
    oled.fill(0)
    oled.show()
  4. Creating an Image Buffer
    An image buffer is created using PIL. This is where the graphics are drawn before being displayed on the screen.
    The PIL(Python Imaging Library) adds image processing capabilities to your Python interpreter. For more detail, please refer to Pillow Handbook.
  5. Drawing Graphics
    Here, a white rectangle (background) and a smaller black rectangle (border effect) are drawn on the image buffer.
    BORDER = 5
    draw.rectangle(
        outline=0,
        fill=0,
  6. Adding Text
    The default font is loaded, and a function to calculate the text size is defined. Then, “Hello World!” is centered and drawn on the image buffer.
    draw.text(
        text,
        font=font,
        fill=255,
  7. Displaying the Image
    Finally, the image buffer is sent to the OLED display for visualization.
    oled.image(image)
    oled.show()
