Lesson 24: Vibration Sensor Module (SW-420)
In this lesson, you will learn how to use a vibration sensor with the Raspberry Pi. We’ll help you connect the sensor to GPIO pin 17 and guide you through writing a simple Python script. This script will monitor the sensor and print a message whenever vibration is detected. This lesson is focused on giving beginners a hands-on experience in connecting a simple sensor to the Raspberry Pi and writing a straightforward script to interact with it.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi 5
../_images/Lesson_24_vibration_sensor_Pi_bb.png
from gpiozero import InputDevice
# Connect the digital output of the vibration sensor to GPIO17 on the Raspberry Pi
vibration_sensor = InputDevice(17)
# Continuous loop to read from the sensor
    # Check if the sensor is active (no vibration detected)
    if vibration_sensor.is_active:
        print("Vibration detected!")
        # When the sensor is inactive (vibration detected)
        print("...")
    # Wait for 1 second before reading the sensor again
    time.sleep(1)
Code Analysis
  1. Importing Libraries
    First, we import necessary libraries: gpiozero for interacting with the GPIO pins, and time for handling time-related functions.
  2. Setting Up the Vibration Sensor
    We initialize the vibration sensor by creating an instance of InputDevice from the gpiozero library. The vibration sensor is connected to GPIO pin 17 on the Raspberry Pi.
  3. Continuous Monitoring Loop
    A while True loop is used for continuous monitoring. This loop will run indefinitely until the program is manually stopped.
  4. Sensor State Check and Output
    • Inside the loop, we use an if statement to check the state of the vibration sensor. If vibration_sensor.is_active is True, it means no vibration is detected, and “Vibration detected!” is printed.
    • If vibration_sensor.is_active is False, indicating vibration, “…” is printed instead.
    • This distinction is crucial for understanding how the sensor’s output is interpreted in the code.
        print("...")
  5. Delay
    Finally, time.sleep(1) adds a 1-second delay between each iteration of the loop. This delay is crucial to prevent the program from overloading the CPU and to make the output readable.
    time.sleep(1)
