Lesson 08: IR Obstacle Avoidance Sensor Module
In this lesson, you will learn how to detect obstacles using a sensor with the Raspberry Pi. We will guide you through connecting a digital input sensor to GPIO pin 17. You’ll learn how to write a Python script that continuously monitors the sensor to determine the presence of an obstacle. The program will output a message indicating whether an obstacle is detected or not. This straightforward yet practical project is an excellent way to get started with GPIO interfacing and Python programming, making it ideal for beginners interested in exploring sensor integration with the Raspberry Pi.
Required Components
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi 5
Wiring
../_images/Lesson_08_Obstacle_Avoidance_Sensor_Pi_bb.png
Code
from gpiozero import InputDevice
from time import sleep
# Initialize the sensor as a digital input device on GPIO 17
sensor = InputDevice(17)
   if sensor.is_active:
      print("No obstacle detected")  # Prints when no obstacle is detected
      print("Obstacle detected")     # Prints when an obstacle is detected
   sleep(0.5)
Code Analysis
  1. Importing Libraries
    The script begins by importing the InputDevice class from the gpiozero library for interacting with the sensor, and the sleep function from Python’s time module for pausing execution.
  2. Initializing the Sensor
    An InputDevice object named sensor is created, connected to GPIO pin 17. This line assumes that the obstacle sensor is connected to this specific GPIO pin.
  3. Implementing the Continuous Monitoring Loop
    • The script uses a while True: loop to continuously check the sensor’s state. This loop will run indefinitely until the program is stopped.
    • Inside the loop, an if statement checks the is_active property of the sensor.
    • If is_active is True, it indicates no obstacle is detected, and “No obstacle detected” is printed.
    • If is_active is False, indicating an obstacle is detected, “Obstacle detected” is printed.
    • sleep(0.5) pauses the loop for 0.5 seconds between each check, which helps in reducing the script’s processing demand and provides a delay between consecutive sensor readings.
        sleep(0.5)
    If the sensor is not working properly, adjust the IR transmitter and receiver to make them parallel. Additionally, you can adjust the detection range using the built-in potentiometer.
