Lesson 28: RGB Module
In this lesson, you will learn how to control an RGB LED module with a Raspberry Pi. You’ll learn how to use Python to change the LED’s color to red, green, blue, and yellow, and then turn it off. This project is a straightforward introduction to working with RGB LEDs and GPIO interfacing, making it ideal for beginners starting with Raspberry Pi and Python programming.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from gpiozero import RGBLED
from time import sleep
from colorzero import Color
# GPIO pin assignments for the RGB LED
red_pin = 22
green_pin = 27
blue_pin = 17
# Initialize the RGB LED with red, green, and blue components connected to their respective GPIO pins
led = RGBLED(red=red_pin, green=green_pin, blue=blue_pin)
# Set the LED to red color (red: 100%, green: 0%, blue: 0%) and wait for 1 second
led.color = (1, 0, 0)
sleep(1)
# Set the LED to green color (red: 0%, green: 100%, blue: 0%) and wait for 1 second
led.color = (0, 1, 0)
sleep(1)
# Set the LED to blue color (red: 0%, green: 0%, blue: 100%) and wait for 1 second
led.color = (0, 0, 1)
sleep(1)
# Set the LED to yellow color using the Color class and wait for 1 second
led.color = Color('yellow')
sleep(1)
# Turn the LED off
led.off()
Code Analysis
Importing Libraries
The script starts with importing the
RGBLEDclass from gpiozero for controlling the RGB LED and thesleepfunction from the time module for delays. It also imports theColorclass from colorzero for color definitions.from gpiozero import RGBLED from time import sleep from colorzero import Color
Initializing the RGB LED
GPIO pins for each color component of the RGB LED are defined.
The RGB LED is initialized with its red, green, and blue components connected to GPIO pins 22, 27, and 17 respectively.
red_pin = 22 green_pin = 27 blue_pin = 17 led = RGBLED(red=red_pin, green=green_pin, blue=blue_pin)
Setting LED Colors
The color of the LED is set to red, green, and blue in sequence, each followed by a 1-second pause.
Colors are represented by tuples (red, green, blue), where each value is between 0 and 1, indicating the intensity.
led.color = (1, 0, 0) sleep(1) led.color = (0, 1, 0) sleep(1) led.color = (0, 0, 1) sleep(1)
Using the Color Class
The script demonstrates how to use the
Colorclass from colorzero to set the LED to a named color (yellow) and then waits for 1 second.In addition to using the pre-defined colors directly, you can also define colors in various ways. For more details, please refer to colorzero.Color.
led.color = Color('yellow') sleep(1)
Turning the LED Off
Finally, the script turns off the LED using
led.off().led.off()
