Lesson 07: Infrared Speed Sensor Module
In this lesson, you will learn how to measure rotational speed using a Raspberry Pi and a simple sensor. We’ll connect a digital input sensor to GPIO pin 17 and use Python to monitor its state changes. The focus will be on calculating revolutions per second by counting the sensor activations over a specific time period. You’ll write a Python function to accurately capture this data and convert it into a measurable speed. This hands-on project is a straightforward yet practical introduction to real-world data collection and analysis with Raspberry Pi, ideal for beginners interested in applied Python programming and hardware interaction.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from gpiozero import DigitalInputDevice
from time import time
# Initialize the sensor
sensor = DigitalInputDevice(17) # Assuming the sensor is connected to GPIO17
def calculate_rps(sample_time=1, steps_per_revolution=20):
Calculate Revolutions Per Second (RPS)
:param sample_time: Sampling time in seconds
:param steps_per_revolution: Number of steps in each complete revolution
:return: Revolutions per second
start_time = time()
end_time = start_time + sample_time
steps = 0
last_state = False
while time() < end_time:
current_state = sensor.is_active
if current_state and not last_state:
# Detect a transition from inactive to active state
steps += 1
last_state = current_state
# Calculate RPS
rps = steps / steps_per_revolution
return rps
# Example usage
print("Measuring RPS...")
rps = calculate_rps() # Default sampling for 1 second
print(f"RPS: {rps}")
# Safely exit the program when a keyboard interrupt is detected
Code Analysis
Importing Libraries
The script starts by importing
DigitalInputDevicefrom gpiozero for sensor interaction andtimefor time management.from gpiozero import DigitalInputDevice from time import time
Initializing the Sensor
A
DigitalInputDeviceobject namedsensoris created, connected to GPIO pin 17. This setup assumes that the digital sensor is connected to GPIO17.sensor = DigitalInputDevice(17)
Defining the
calculate_rpsFunctionThis function calculates the Revolutions Per Second (RPS) of a rotating object.
sample_timeis the duration in seconds for which the sensor’s output is sampled.steps_per_revolutionrepresents the number of sensor activations per complete revolution.The function uses a while loop to count the number of steps (sensor activations) within the sample time.
It detects transitions from inactive to active states and increments the
stepscount accordingly.RPS is calculated as the number of steps divided by
steps_per_revolution.
def calculate_rps(sample_time=1, steps_per_revolution=20): """ Calculate Revolutions Per Second (RPS) :param sample_time: Sampling time in seconds :param steps_per_revolution: Number of steps in each complete revolution :return: Revolutions per second """ start_time = time() end_time = start_time + sample_time steps = 0 last_state = False while time() < end_time: current_state = sensor.is_active if current_state and not last_state: # Detect a transition from inactive to active state steps += 1 last_state = current_state # Calculate RPS rps = steps / steps_per_revolution return rps
Running the Main Loop
The script then enters a continuous loop where it calls
calculate_rpsto calculate and print the RPS.The loop runs indefinitely until a keyboard interrupt (Ctrl+C) is detected.
A
try-exceptblock is used to handle the interrupt gracefully, allowing for a safe exit.
try: while True: rps = calculate_rps() # Default sampling for 1 second print(f"RPS: {rps}") except KeyboardInterrupt: pass
