Lesson 20: Temperature, Humidity & Pressure Sensor (BMP280)
In this lesson, you will learn how to connect and read data from a BMP280 sensor that measures temperature, humidity, and pressure using a Raspberry Pi. You’ll set up the sensor and write a Python script to measure environmental data including temperature, atmospheric pressure, and altitude.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
Install Library
The adafruit-circuitpython-bmp280 library relies on Blinka, so please ensure that Blinka has been installed. To install libraries, refer to Insatll Adafruit_Blinka (CircuitPython) - Optional.
Before installing the library, please make sure that the virtual Python environment is activated:
source ~/env/bin/activate
Install adafruit-circuitpython-bmp280 library:
pip install adafruit-circuitpython-bmp280
Run the Code
Please ensure that you have installed the Python library required for running the code according to the “Install Library” steps.
Before running the code, please make sure that you have activated the virtual Python environment with blinka installed. You can activate the virtual environment using a command like this:
Find the code for this lesson in
universal-maker-sensor-kit-main/pi/directory, or directly copy and paste the code below. Execute the code by running the following commands in terminal:python 22_touch_sensor_module.py
import board
import adafruit_bmp280
# Create sensor object, communicating over the board's default I2C bus
i2c = board.I2C() # uses board.SCL and board.SDA
bmp280 = adafruit_bmp280.Adafruit_BMP280_I2C(i2c,address=0x76)
# change this to match the location's pressure (hPa) at sea level
bmp280.sea_level_pressure = 1013.25
print("\nTemperature: %0.1f C" % bmp280.temperature)
print("Pressure: %0.1f hPa" % bmp280.pressure)
print("Altitude = %0.2f meters" % bmp280.altitude)
time.sleep(2)
print("Exit") # Exit on CTRL+C
Code Analysis
Setting up the sensor
Import necessary libraries and create an object to interact with the BMP280 sensor.
board.I2C()sets up the I2C communication.adafruit_bmp280.Adafruit_BMP280_I2C(i2c, address=0x76)initializes the BMP280 sensor with its I2C address.For more detail about the
adafruit_bmp280library, please refer to adafruit/Adafruit_CircuitPython_BMP280.import time import board import adafruit_bmp280 i2c = board.I2C() bmp280 = adafruit_bmp280.Adafruit_BMP280_I2C(i2c, address=0x76)
Configuring sea-level pressure
Set the
sea_level_pressureproperty of the BMP280 object. This value is needed to calculate altitude.bmp280.sea_level_pressure = 1013.25
Reading data in a loop
Use a
while Trueloop to continuously read data from the sensor.bmp280.temperature,bmp280.pressure, andbmp280.altituderead the temperature, pressure, and altitude, respectively.time.sleep(2)pauses the loop for 2 seconds.try: while True: print("\nTemperature: %0.1f C" % bmp280.temperature) print("Pressure: %0.1f hPa" % bmp280.pressure) print("Altitude = %0.2f meters" % bmp280.altitude) time.sleep(2) except KeyboardInterrupt: print("Exit")
Handling interruptions
The
tryandexcept KeyboardInterrupt:block allows the program to exit gracefully when you press CTRL+C.try: # while loop code here except KeyboardInterrupt: print("Exit")
