Lesson 34: TT Motor
In this lesson, you will learn how to control the speed and direction of a motor using a Raspberry Pi. You’ll learn how to program the Raspberry Pi to run the motor at different speeds and in both forward and backward directions. The project will involve setting the motor speed, running it for a specified duration, and then stopping it. This exercise is a practical introduction to motor control with the Raspberry Pi, offering a clear and straightforward experience in hardware control and Python programming, suitable for beginners.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi 5
TT Motor
L9110 Motor Driver Module
../_images/Lesson_34_Motor_Pi_bb.png
from gpiozero import Motor
from time import sleep
# Define motor pins
motor = Motor(forward=17, backward=27)  # Using Raspberry Pi GPIO pin numbers
# Run the motor forward at half speed
motor.forward(speed=0.5)  # Set motor speed, range is 0 to 1
sleep(5)                  # Run the motor for 5 seconds
# Increase to full speed forward
motor.forward(speed=1)    # Set motor speed, range is 0 to 1
# Run the motor backward at full speed
motor.backward(speed=1)   # Set motor speed, range is 0 to 1
# Stop the motor
motor.stop()
Code Analysis
  1. Import Libraries
    Import the Motor class from gpiozero for motor control, and sleep from time for timing control.
  2. Define Motor Pins
    Create a Motor object to control a motor connected to GPIO pins 17 and 27 for forward and backward movements, respectively.
  3. Run the Motor Forward at Half Speed
    The motor is run forward at half speed (speed=0.5) for 5 seconds. The speed range is between 0 (stopped) and 1 (full speed).
    sleep(5)
  4. Increase to Full Speed Forward
    Increase the motor speed to full speed (speed=1) in the forward direction, running for another 5 seconds.
    sleep(5)
  5. Run the Motor Backward at Full Speed
    The motor is then run backward at full speed for 5 seconds.
    sleep(5)
  6. Stop the Motor
    Finally, stop the motor using the stop method.
    motor.stop()
