Lesson 03: Flame Sensor Module
In this lesson, you will learn to use a flame sensor with Raspberry Pi for fire detection. We’ll show you how to connect the flame sensor to GPIO17 and write a Python script to read its output. You’ll learn to identify when the sensor detects a flame, indicated by a change in the sensor’s state. This practical project introduces you to the basics of sensor interfacing and Python coding on the Raspberry Pi, suitable for beginners interested in building safety-related projects.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from gpiozero import InputDevice
# Connect the digital output of the flame sensor to GPIO17 on the Raspberry Pi
flame_sensor = InputDevice(17)
# Continuous loop to read from the sensor
# Check if the sensor is active (no flame detected)
if flame_sensor.is_active:
print("No flame detected.")
# When the sensor is inactive (flame detected)
print("Flame detected!")
# Wait for 1 second before reading the sensor again
time.sleep(1)
Code Analysis
Importing Libraries
The script starts by importing the necessary classes from the gpiozero library and the time module from Python’s standard library.
from gpiozero import InputDevice import time
Initializing the Flame Sensor
An
InputDeviceobject namedflame_sensoris created, representing the flame sensor connected to GPIO pin 17 of the Raspberry Pi. This setup assumes that the digital output of the flame sensor is connected to GPIO17.flame_sensor = InputDevice(17)
Continuous Reading Loop
The script uses a
while True:loop to continuously read the sensor’s data. This loop will run indefinitely.Inside the loop, an
ifstatement checks the state of the flame sensor using theis_activeproperty.If
flame_sensor.is_activeisTrue, it indicates no flame is detected, and “No flame detected.” is printed.If
flame_sensor.is_activeisFalse, it indicates a flame is detected, and “Flame detected!” is printed.The
time.sleep(1)command pauses the loop for 1 second between each sensor reading, preventing the script from overloading the CPU.
while True: if flame_sensor.is_active: print("No flame detected.") else: print("Flame detected!") time.sleep(1)
