Lesson 23: Ultrasonic Sensor Module (HC-SR04)
In this lesson, you’ll learn how to connect an ultrasonic distance sensor to a Raspberry Pi and write a Python script for reading distance measurements. We’ll guide you through the process of wiring the sensor’s trigger pin to GPIO 17 and the echo pin to GPIO 27. The provided Python code will assist you in measuring distances and displaying them in centimeters.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from gpiozero import DistanceSensor
from time import sleep
# Initialize the DistanceSensor using GPIO Zero library
# Trigger pin is connected to GPIO 17, Echo pin to GPIO 27
sensor = DistanceSensor(echo=27, trigger=17)
# Main loop to continuously measure and report distance
dis = sensor.distance * 100 # Measure distance and convert from meters to centimeters
print('Distance: {:.2f} cm'.format(dis)) # Print the distance with two decimal precision
sleep(0.3) # Wait for 0.3 seconds before the next measurement
# Handle KeyboardInterrupt (Ctrl+C) to gracefully exit the loop
Code Analysis
Importing Libraries
The script begins by importing
DistanceSensorfrom the gpiozero library for the ultrasonic sensor, andsleepfrom the time module for timing control.from gpiozero import DistanceSensor from time import sleep
Initializing the Distance Sensor
A
DistanceSensorobject namedsensoris created withechoandtriggerpins connected to GPIO 27 and GPIO 17, respectively. These pins are used to send and receive the ultrasonic signals for distance measurement.sensor = DistanceSensor(echo=27, trigger=17)
Implementing the Continuous Monitoring Loop
A
tryblock with an infinite loop (while True:) is used to continuously measure the distance.Within the loop,
sensor.distancegives the measured distance in meters, which is then converted to centimeters and stored indis.The distance is printed with two decimal points of precision using the
formatmethod.sleep(0.3)adds a 0.3-second delay between each measurement to control the frequency of readings and reduce CPU load.
try: while True: dis = sensor.distance * 100 print('Distance: {:.2f} cm'.format(dis)) sleep(0.3)
Handling KeyboardInterrupt for Graceful Exit
The
exceptblock is used to catch a KeyboardInterrupt (typically Ctrl+C). When this occurs, the script exits the loop gracefully without any additional actions.except KeyboardInterrupt: pass
