Lesson 09: Joystick Module
The Raspberry Pi does not have analog input capabilities, so it needs a module like the PCF8591 ADC DAC Converter Module to read analog signals for processing.
In this lesson, you will learn how to use a Raspberry Pi to interface with a joystick module using the PCF8591 ADC. You’ll be able to read the X and Y positions of the joystick from its analog outputs and detect button presses. This setup demonstrates how to handle both analog and digital inputs on a Raspberry Pi.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi 5
Joystick Module
In this project, we utilized the AIN0 pin of the PCF8591 module, which is linked to a potentiometer on the module through a jumper cap. To prevent data interference, please disconnect the jumper cap from the module. For more details, please refer to the PCF8591 module schematic.
../_images/Lesson_09_Jostick_Module_pi_bb.png
import PCF8591 as ADC  # Import ADC module for analog input
import time  # Import time module for creating delay
from gpiozero import Button  # Import Button for button input
ADC.setup(0x48)  # Set up PCF8591 module at I2C address 0x48
button = Button(17)  # Initialize button connected to GPIO 17
    while True:  # Loop continuously
        print("x:", ADC.read(0))  # Read analog value from channel AIN0
        print("y:", ADC.read(1))  # Read analog value from channel AIN1
        print("sw:", button.is_active)  # Check if button is pressed
        time.sleep(0.2)  # Wait for 0.2 seconds before next loop
    print("Exit")  # End program on keyboard interrupt
Code Analysis
  1. Import Libraries:
    The script starts with importing necessary libraries for the project.
  2. Setup PCF8591 Module:
    The PCF8591 module is set up at I2C address 0x48 which allows the Raspberry Pi to communicate with it.
  3. Initialize Button:
    A button is initialized, connected to GPIO pin 17 on the Raspberry Pi.
  4. Main Loop:
    The main part of the script is an infinite loop that continuously reads analog values from two channels of the PCF8591 (AIN0 and AIN1) and checks if the button is pressed. AIN0 and AIN1 are analog pins for the joystick’s X and Y axes.
  5. Interrupt Handling:
    The script can be exited gracefully using a keyboard interrupt (CTRL+C), which is a common practice in Python for stopping an infinite loop.
